Call Forward Issue
Jul 27th, 2009
Hi all,
I am facing an issue in callforward functionality for a perticular extension. Call forward is not happening on one extension, It gives a busy after the ring duration. I have verified the CSS and partition all are fine, and this extension is only associated with one device profile. No other dependencies..
All other extensions are working fine. Kindly advice..
Nahas
Carlo Poggiarelli Mon, 07/27/2009 - 06:56
  • Green, 3000 points or more
If you have callmanager version 6.x or 7.x,on DN configuration page, check the "Calling Search Space Activation Policy" parameter. If you leave the default value, you have to specify the css beside every forwarding option you are configuring. Changing this parameter you can choose to use the dn's css to route forwarded calls
Bye
Carlo
Nahassamad_2 Tue, 07/28/2009 - 00:59
Thanks for your response..
I have tried configured CSS and Activating device/line css bith. But problem is only on a perticular extension.
Please advice..
Nahas
Carlo Poggiarelli Tue, 07/28/2009 - 04:13
Hi Nahas.
On "route plan report" check if another extension has the same dn with another partition.
Are you able to call that extension even from the phone you are applying forwoarding rules?
Let me know.
Bye
Carlo
Nahassamad_2 Tue, 07/28/2009 - 20:29
HI Carlo,
This is the only number in route plan report.
Nahas
