Cisco 1811 Router = Linksys Rv082 VPN Router
Jul 27th, 2009
Can I use the Cisco 1811 Router as Linksys's Rv082 VPN Router works,,
I want to run 2 internet connections, first one will be dedicated to the VPN traffic and the second one will be using for general internet surfing,,
Any idea,,
Junaid
mmacdonald70 Mon, 07/27/2009 - 15:40
It should work fine. Create a default route out one interface and a static route to the endpoint of the VPN out the other
junshah22 Mon, 07/27/2009 - 18:23
Do you have any sample configuration???
This will help me in better understanding..
