CUCM conversion from DLU to CUWL
Answered Question
When do the "technical" aspect of the license conversion, do you just upload new CUWL license(s)? Since they look just like DLUs (but with larger numbers) when you do the "license unit report"; after uploaded, I would think the license unit report would show the DLUs + the CUWL numbers. Is there a way to delete the DLU license files? (I'd assume a CUCM service restart would be in order after the swap).
Has anyone stepped through this procedure?
Thanks!
Correct Answer by Tommer Catlin about 7 years 12 months ago
There is nothing you need to do on the server end. If anything, you will be adding DLUs to the server. Basically certain number of DLU's are for registering phones.
So for example, if I had 7940 that takes up 4 DLUs (or whatever it is). Then the customer wanted to have IPC communicator for that same line, another 3 DLUs and CUPC for that person, 1 DLUs. So total is 8 DLUs needed.
To make it easier for purchasing, the CUWL license is 1 license to purchase, but includes 8 DLUs that get installed on the server (all examples here). When you load the DLUs, you will have more DLUs than you need unless you max out the example above.
make sense?
So if Cisco shows you have 2500 DLUs that you purchased or have on your server and the backend licensing and you convert them to CUWL, to make up the difference, they may give you 1000 DLUs to balance it out to 3500 DLUs. You may get a PAK key with 1000 DLUs to install on the server and now it is "technically" a CUWL licensed.
Overall Rating: 5 (1 ratings)
Correct Answer
Tommer Catlin Mon, 07/27/2009 - 08:34
  • Green, 3000 points or more
make sense?
Tommer Catlin Mon, 07/27/2009 - 10:20
it's not well documented anywhere, but your local Cisco SE should pretty much say the same thing.
