Router 877-K9 IPSEC
Jul 27th, 2009
Dear Cisco Support,
I have one clarification to be made on product 877-k9 Router.
Does it support Remote access VPN IPSEC server, If so how many client users can connect to router using IPSec Say 10,20.. and does it require any licensing for upgrading to this feature if not which IOS is suitable for this?
Please be kind to reply as soon as possible
Roman Rodichev Mon, 07/27/2009 - 04:56
yes it can be ipsec vpn server and my notes show that it can do 10 3des tunnels and 2 ssl vpn clients
there are only two feature sets for 87x, advanced security and advanced ip services. Both feature sets can do what you want. If you want to do DMVPN, you will need advanced ip services that supports NHRP
regards,
roman
rohandast Mon, 07/27/2009 - 05:29
Thanks for your comments. My current issue is I have to create Remote access VPN by installing IPSec client Not the Site to Site VPN as you were suggesting. I belive it support 10 SSL VPN client and we need to obtain license for that. But I dont know about IPsec VPN whether it supports that. Please advice on the same
