ACE port redirection
Answered Question
Jul 27th, 2009
Hi Experts,
I need your help,
Is it possible to do port redirection on ACE . For example. a user is accessing the Loadbalancer VIP on port 80 and this is redirected to port 8080 on backend servers?
Any help will be appreciated. Thanks in advance guys.
Any documnet or link in this regard would be helpful.
RObertS
Correct Answer by sachinga.hcl about 7 years 5 months ago
HI
Yes this is possible by just adding the port-number after the rserver name when defining the serverfarm.
For example:
rserver server1
ip address 10.20.30.41
inservice
rserver server2
ip address 10.20.30.42
inservice
serverfarm www-servers
rserver server1 8080
inservice
rserver server2 8080
inservice
class-map test
match virtual-address 10.20.30.40 tcp port eq 80
This way, the VIP will be on port 80, and the ACE will communicate with the real servers on port 8080.
Kindly check below URL for Configuring Static NAT and Port Redirection
http://docwiki.cisco.com/wiki/Cisco_Application_Control_Engine_(ACE)_Module_Troubleshooting_Guide,_Release_A2(x)_--_Troubleshooting_Network_Address_Translation
Kindly Rate if you find this information useful to you.
Sachin Garg
Overall Rating: 5 (2 ratings)
Correct Answer
sachinga.hcl Mon, 07/27/2009 - 05:32
HI
For example:
rserver server1
inservice
rserver server2
inservice
inservice
inservice
class-map test
Sachin Garg
robertsmith.net... Mon, 07/27/2009 - 05:36
HI Sachin
Thanks for your quick response.
However just want to know whether ping is allowed since we mention only port 80 in the virtual address? DO i need to add something on the top of this to allow ping also.
Kindly help.
RobertS
sachinga.hcl Mon, 07/27/2009 - 05:40
Hi Robert,
If you want to allow ping to the VIP address, you only need to apply this command in your L3-4 policy map:
loadbalance vip icmp-reply
example:
policy-map multi-match L4-TEST-VIPS
class WWW-TEST
loadbalance vip inservice
loadbalance policy WWW_POLICY
more info can be found here:
http://www.cisco.com/en/US/docs/interfaces_modules/services_modules/ace/v3.00_A2/configuration/slb/guide/classlb.html#wp1000929
If you want ICMP to pass through the ACE tp reach the real servers, you need to allow it in an ACL.
Hope this helps,
Sachin Garg
lingaraj19 Wed, 08/21/2013 - 05:09
If I want to redirect the with mulitple ports. for example, front end port which i am using is 80 and in back end it should be load balanced with the port 8080.8081,8082,9090
is it possible to configure and if yes kindly help me with the steps.
thanks in advance.
Lingaraj R N
