NAT Table Info
I have two routers (RTRA & RTRB) setup on a frame relay network. RTRA acts as the primary while RTRB acts as the secondary. Both routers are using NAT. If connection to RTRA fails traffic would failover to the secondary, causing the NAT Table to populate.
My question is how long would the system store the NAT Table on RTRB if traffic was restored on the primary? Will RTRB maintain the NAT Table until the router was reloaded?
Endwigast Mon, 07/27/2009 - 07:02
configure ka stateful NAT para pag nag failover hindi maputol yung mga tcp connections due to nat repopulation :)
Endwigast Mon, 07/27/2009 - 07:22
sa yehey na word :D
pag naka SNAT mag replicate yung NAT table mo sa kabilang equipment. naka mirror yun. so kung ano laman nung active router NAT table yun din laman nung backup router NAT table. hindi mag expire yung translation kse kung mini mirror lang nya yung laman galing sa active. naka SNAT ka pala? nasa pinas ka ba? nasa pinas ako e hehe
