ASA 5510 Firewal ACL HITCOUNT
Answered Question
I have a simple question but I am having a hard time getting an answer. WHen you do show access-list command on the ASA 5510 there is a hit count ....i know how to clear that but I want to knowis there a default timer that will clear the hit count ? Or does the hit count remain till I clear the count? I am trying to clean up some ACLs and for future troubleshooting I would like to know that. I dont want to remove an ACL entry with 0 hitcount and then it is needed.
Correct Answer by Collin Clark about 7 years 5 months ago
The counters are there until one of two things happen; you clear them manually or you reboot the device. There are no timers to clear the counters. We usually clear the counters, let it run for a month or so then clean it up.
Hope that helps.
Overall Rating: 5 (1 ratings)
Correct Answer
Collin Clark Mon, 07/27/2009 - 11:27
Hope that helps.
