Security level on ASA
Answered Question
Jul 27th, 2009
Hi Experts,
If there are multiple sub interfaces and vlans are created with different security levels
Will the traffic flows from high security level interface to low security level interface?.
What is the case if we have the acls in place?
Thanks in advance
Madan.
Correct Answer by Jon Marshall about 8 years 1 day ago
Depends on what you are trying to do with your acl.
There is an implicit deny at the end of an acl so anything not explicitly permitted or denied in your acl will be dropped.
Jon
Correct Answer by John Blakley about 8 years 1 day ago
Madan,
The ASA always allows traffic from higher to lower by default. If you have ACLs in place, then you'll need to allow the traffic through.
For example, if you have an ACL applied to the inside interface and the inside interface has a security level of 100, then that ACL will need to allow what you want out. If you want users to be able to surf the web, but nothing else, your acl will allow port 80 out, but deny everything else.
HTH,
John
Overall Rating: 5 (2 ratings)
Correct Answer
John Blakley Mon, 07/27/2009 - 08:15
  • Purple, 4500 points or more
Madan,
HTH,
John
kr_madan Mon, 07/27/2009 - 09:00
Thanks for your valuable input.
Do we need Explicit deny statement in acl?
Correct Answer
Jon Marshall Mon, 07/27/2009 - 09:06
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Jon
John Blakley Mon, 07/27/2009 - 09:11
In addition to what Jon said, if you use a permit any at the end of your acl and want to deny traffic, you'll need a deny line before the permit any.
deny ip 192.168.1.0 255.255.255.0 any eq 80
permit ip any any
This would deny 192.168.1.0 subnet from getting on the web, but it would allow them to go everywhere else like mail, etc. After the "permit ip any any" line is an "invisible" deny ip any any line. You can't see it but it's there. I normally put a deny ip any any at the end so I can see what I'm actually blocking hit-count wise.
John
