07-27-2009 07:45 AM - edited 03-04-2019 05:33 AM
How many vrf's can i make using ospf as PE-CE routing protocol.The platform is 7609 router.and using iBGP as PE-PE routing protocol.
07-27-2009 09:08 AM
Hello Nishant,
in first implementation of OSPF as PE-CE the limit was counted against the max number of OSPF processes on the box and was in the order of 30.
A successive implementation has removed this limit for VRF OSPF instances.
see
or
if you have an IOS >
12.2(18)SXE
This feature was integrated into Cisco IOS Release 12.2(18)SXE.
12.2(27)SBC
This feature was integrated into Cisco IOS Release 12.2(27)SBC.
You should be fine
Hope to help
Giuseppe
08-06-2009 03:04 PM
Thanks Giueseppe.
I have gone through the links and found one ambigious statement."Only 32 processes per VRF can be supported. For different VRF processes, there is no limit. "
Can you elaborate on this statement?
Appreciate your help
