Catalyst 4006 L3 Switch (RMON?)
Jul 27th, 2009
I have ver 12.1.(13)EW on this switch. We have a Fluke OptiView to help in network troubleshooting. But in order to pull a history from the device I have to turn on RMON.. In the 4006 under config t... You have two choice with RMON alarm or RMON event I don't understand how I use these so I can see the usage history from our Fluke Optiview...
Giuseppe Larosa Mon, 07/27/2009 - 09:01
  • Hall of Fame,
    Founding Member
Hello David,
you can use the following for RMON
http://www.cisco.com/en/US/partner/docs/ios/netmgmt/configuration/guide/nm_cfg_rmon_sup_ps6017_TSD_Products_Configuration_Guide_Chapter.html
or
http://www.cisco.com/en/US/docs/ios/netmgmt/configuration/guide/nm_cfg_rmon_sup_ps6017_TSD_Products_Configuration_Guide_Chapter.html
with RMON the devices collects SNMP MIB variables over time on itself and can send messages (alarms) when a specified condition (event) happens this is different from SNMP polling where an agent performs gets every x minutes.
Hope to help
Giuseppe
glynncounty Mon, 07/27/2009 - 09:08
Router(config-if)# rmon collection history {controlEntry integer} [owner ownername] [buckets bucket-number] [interval seconds]
Enables an RMON history group of statistics on an interface.
rmon collection history is what I believe I have and naturally I guess either my IOS doesn't support it or I need another Sup engine.
jbrenesj Mon, 07/27/2009 - 09:12
  • Silver, 250 points or more
4000 IOS 12.1 only supports mini-RMON
What sup model do you have?
glynncounty Mon, 07/27/2009 - 09:15
according to cisco view...
WS-X4515 Supervisor Engine IV
Giuseppe Larosa Mon, 07/27/2009 - 09:17
  • Hall of Fame,
    Founding Member
Hello David,
the link I've provided is not specific of your platform.
of course what you see is what you can get on the device.
Hope to help
Giuseppe
jbrenesj Mon, 07/27/2009 - 09:22
Supervisor Engine IV can run 12.2 codes so you can consider moving to a newer IOS but consult with Fluke to know what kind of config you need on the switch for your particular traffic/event monitoring needs
