Delete Partitions and CSS
Answered Question
Jul 27th, 2009
hi,
I am trying to delete some unused partitions and CSS which are not assigned to any devices. I verified this by running a dependency records which resulted as 0 for both the PT and CSS. when I try to delete them, it says they are referenced in the database. Any idea how to overcome this problem?
CCM version is 5.1.3 build 5106
thanks for the help.
Correct Answer by gogasca about 7 years 11 months ago
I would open a TAC case since it may require informix db access to delete partitions manually from DB
Overall Rating: 3 (1 ratings)
Correct Answer
gogasca Tue, 07/28/2009 - 08:14
  • Green, 3000 points or more
kraghavansag Tue, 07/28/2009 - 09:16
hi,
thanks for your response. That's what I was thinking to do. but wanted to check in forum before opening a TAC.
