Difference between CP-PWR-CUBE and CP-PWR-CUBE-3 for 7941G
Jul 27th, 2009
Anybody know if an older CP-PWR-CUBE will fit and work with a 7941G ?
Cisco recommends the CP-PWR-CUBE-3 in the user guide but the specs seem to be exactly the same.
I just want to know whether I can just buy the cheaper CP-PWR-CUBE for my 7941G and I won't have any issues using it.
Overall Rating: 5 (2 ratings)
Rob Huffman Tue, 07/28/2009 - 04:39
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Alan,
Because the 7941G supports Cisco pre-standard power the CP-PWR-CUBE will work just fine :)
Hope this helps!
Rob
sabb010101 Wed, 07/29/2009 - 10:22
Thanks Rob
I have read on the web that CP-PWR-CUBE-3 has a longer plug to fit the 7941G, 7961G and 7971G and hence my question about whether the older CP-PWR-CUBE will fit and power up the 7941G.
I understand that the CP-PWR-CUBE-3 is backward comptible with older phones but is the CP-PWR-CUBE forward compatible with the newer phones ?
Rob Huffman Wed, 07/29/2009 - 10:46
  • Hall of Fame,
    Founding Member
Hi Alan,
The plug is a little longer because on the newer IP Phone models like the 7941G there is an additional piece of plastic (in a semi circle) around the power plug input on the base of the phone. This can be easily trimmed with a pair of side-cutters and you are good to go :) It depends on how much $$ you will be saving, if you want to go this direction. A 30 second trim job and "Bob's your Uncle"!
Hope this helps! Cheers!
Rob
davidlu766 Wed, 07/29/2009 - 18:18
Yes, there is a difference. If you have a 79x1, you MUST have a CP-PWR-CUBE-3 or a POE switch, otherwise it just won't work. The CP-PWR-CUBE is ONLY for the 7940G and the 7960G. If you use it with the 7941G or 7961G it won't fit.
Hope that helps.
Rob Huffman Thu, 07/30/2009 - 05:57
  • Hall of Fame,
    Founding Member
Hi Alan,
David is right here (my bad!!) +5 points for this David :)
I just took my own advice and tried a CP-PWR-CUBE with a 7941G. Even with the modifications I suggested it did not fit properly and would be unusable. I could have sworn we did this b4 but.......
Anyways, sorry for leading you down the wrong path here, I should have tested before I responded.
Cheers!
Rob
sabb010101 Thu, 07/30/2009 - 07:44
Thanks a lot David and Rob for your prompt replies.
Now I know for sure that I should not waste my money on a CP_PWR_CUBE !
Rob Huffman Thu, 07/30/2009 - 08:06
  • Hall of Fame,
    Founding Member
Hi Alan,
You are most welcome my friend! Sorry for the "bum" info.
Cheers!
Rob
Cory Andrews Thu, 12/13/2012 - 10:03
There are some companies out there making 3rd party universal power supplies for Cisco CP-79XX Series desktop phones.  These folks offer a backward compatible version of the Cisco CP-PWR-CUBE3.
