07-27-2009 01:05 PM - edited 03-04-2019 05:34 AM
I have a 2621 router and trying to configure netflow on the S0/0 interface. However, ip flow egress is not available on this IOS. So i did a search for latest IOS that support this command. unfortunately Cisco does not support an IOS that availabe to 2621.
Does someone has alternatve command for IP flow egress or a way to get around to install 12.3T on this router?
thanks
07-27-2009 01:41 PM
Try:
ip route-cache flow
HTH,
John
07-28-2009 05:08 AM
they are actually the same. this is what i found from cisco command tool.
Effective with Cisco IOS Releases 12.4(2)T and 12.2(18)SXD, the ip route-cache flow command is replaced by the ip flow ingress command. See the ip flow ingress command for more information.
To enable NetFlow (ingress) accounting for traffic arriving on an interface, use the ip route-cache flow command in interface configuration mode. To disable NetFlow (ingress) accounting for traffic arriving on an interface, use the no form of this command in interface configuration mode.
what i missing is ip flow egress? is there an alternate command for it?
thanks
07-28-2009 07:12 AM
As you have indicated, 'egress' support started with 12.3(11)T and 2621 only support up to 12.3(Mainline).
Your only option is to enable ingress NetFlow accounting on each interface of the router or upgrade to a newer hardware.
When that hardware was built, NetFlow was a fairly new feature that only supported ingress accounting.
HTH,
__
Edison.
