fail over ASA
Answered Question
Jul 27th, 2009
Ihave two ASA 5520, I am new to ASA as a fail over, I would like to know how I can view if the two firewalls states and which firewall is active
Correct Answer by Jon Marshall about 7 years 9 months ago
Shane
"sh mode" shows you which mode the firewall is running in.
To switch between firewalls either
1) on the current standby firewall use the command - "failover active"
OR
2) on the current active firewall use the command - "no failover active"
http://www.cisco.com/en/US/docs/security/asa/asa72/command/reference/ef_72.html#wp1759150
Jon
Correct Answer by srue about 7 years 9 months ago
show failover
Overall Rating: 5 (3 ratings)
Correct Answer
srue Mon, 07/27/2009 - 14:04
  • Blue, 1500 points or more
show failover
shanemcanuff Wed, 07/29/2009 - 12:54
thanks that works, how do I change over to the primary firewall, and what command I use to see the mode the two firewall is running in?
Correct Answer
Jon Marshall Wed, 07/29/2009 - 13:18
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
Shane
OR
Jon
shanemcanuff Wed, 07/29/2009 - 15:06
Thanks a lot, for some reason I was not able to failover, when I went to the data center I saw that one of the firewall was off.
