ANI database engine service terminated unexpectedly
Jul 27th, 2009
I was having issues last week with the ANIServer process (busy flag set). I had used the following:
NMSROOT/bin/perl NMSROOT/bin/dbRestoreOrig.pl dsn=ani dmprefix=ANI
which helped to get the server to a stable state (all processes running, no apparent issues).
I just rebooted the server today and found the following in the event logs. To get the server back up and running, I use the above command again.
Has anyone else been running into this issue?
The CiscoWorks ANI database engine service terminated unexpectedly. It has done this 1 time(s).
For more information, see Help and Support Center at http://go.microsoft.com/fwlink/events.asp.
The application, C:\PROGRA~1\CSCOpx\objects\db\win32\dbsrv10.exe, generated an application error The error occurred on 07/27/2009 @ 17:04:13.203 The exception generated was c0000005 at address 00000008 (<nosymbols>)
Joe Clarke Mon, 07/27/2009 - 16:38
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
It's entirely possible that the shutdown corrupted the database. Windows does not wait long enough for Daemon Manager to stop when it performs a shutdown/restart. Therefore, it is ALWAYS recommended to do a "net stop crmdmgtd" before you shutdown or reboot a server to ensure that all of the databases are shutdown properly.
david.fernandes... Mon, 07/27/2009 - 16:57
In this case, I did use "net stop crmdmgtd" first, ran a backup job to image the server, and then rebooted. The error happened after that.
Joe Clarke Mon, 07/27/2009 - 17:01
  • Cisco Employee,
  • Hall of Fame,
    Founding Member
You might have a bad disk. Can you reproduce this simply by shutting down Daemon Manager, and rebooting? I have LMS 3.2 installed on two Windows servers, and two Solaris servers, and I am not seeing any such corruption issues.
