Cisco 2924 Extended VLAN
Jul 27th, 2009
Could I create extended VLAN on a 2900 switch? i.e. 1006 - 4094, I don't have any test equipment. I don't want to test it on production environment.
SWITCH01#Sho ver
System image file is "flash:c2900XL-h2s-mz-120.5.1-XP.bin"
cisco WS-C2924M-XL
SWITCH01#sho vtp stat
VTP Version : 2
Configuration Revision : 26
Maximum VLANs supported locally : 254
Number of existing VLANs : 21
VTP Operating Mode : Server
Thanks.
Gil
Leo Laohoo Mon, 07/27/2009 - 21:50
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Hi Gil,
Have you tried using the latest IOS, WC17?
gill.juguilon Mon, 07/27/2009 - 22:27
Hi Leo,
I haven't tried upgrading the IOS yet.
I already downloaded the IOS in case an upgrade is needed.
If I could create extended VLAN in transparent mode. Then my problem is solve.
Thanks for the reply.
Gil
jbrenesj Tue, 07/28/2009 - 09:43
  • Silver, 250 points or more
Unfortunately I just tested it on my
WS-C2924M-XL running IOS Version 12.0(5)WC17 and it doesn't support extended vlans
WS-C2924M-XL-A(vlan)#vlan ?
<1-1005> ISL VLAN index
gill.juguilon Tue, 07/28/2009 - 15:06
Could you please try to change the VTP operation mode to Transparent. Then create an extended VLAN. If it doesn't work then I have no choice but to change the switch.
Thanks and regards,
Gil
Leo Laohoo Tue, 07/28/2009 - 14:41
  • Hall of Fame,
    2017 LAN, Wireless
Hi Gil,
Apologize for wasting your time. The 2900/3500 switches are very "simple" models. I have a nagging suspicion it doesn't support extended VLANs but I can't confirm because I couldn't find any documentations nor do I have a sample to test it out.
gill.juguilon Tue, 07/28/2009 - 15:12
Hi Leo,
If this is not doable then I have no choice but to change the switch.
Thanks for information and help.
I appreciate it. :)
Gil
jbrenesj Tue, 07/28/2009 - 15:27
Just changed it to transparent. Sorry, there is no extended vlan support
