ping not working from one firewall to other devices
Jul 27th, 2009
I am connected via vpn to a firewall to the network which allots ip pool.Now once connected, i cannot ping any of the other devices in the network.Logs on firewall show deny, so i decided to add an acl for this permit icmp any any to the particular inside interface.But it still shows same results & same log in the firewall.
There is another firewall in the path after this to reach other devices.
What commands would make this work?
Thanks.
suthomas1 Tue, 07/28/2009 - 01:11
Thanks Reda,
how do we enable return traffic for ping?
I meant that once i login through VPN to my organisations network, then i need to access/ping other network devices which are within this environment.Do we need anything specific to be done...
you can do it in 2 ways:
- Enable ICMP inspection, then the ASA will consider ICMP traffic as a Stateful traffic, and will accept the icmp-echo reply. most secure.
- allow ICMP echo reply in the outside interface:
object-group icmp-type Icmp-Reply
icmp-object echo-reply
icmp-object time-exceeded
icmp-object unreachable
access-list allbxx extended permit icmp any any object-group Icmp-Reply
this is only an example, but it should help you.
let me know if you it solve the issue.
