Unable to get MSE status.
Jul 27th, 2009
My WCS reported the MSE was disconnected. Then i checked the mse status.
[[email protected] ~]# service msed start
Starting MSE Platform
MSE Platform is already running
[[email protected] ~]# service msed status
MSE Platform is up, getting the status
Unable to get MSE status. Error: java.net.SocketTimeoutException: Read timed out
Retrying status fetch -
Any idea or solution about this? thanks a lot.
Overall Rating: 5 (1 ratings)
ericgarnel Tue, 07/28/2009 - 07:02
Have you tried either of the following:
restarted msed altogether and/or rebooted the appliance?
Can you also provideoutput from the following commands
netstat -tap
ps -ef|grep mcsed
what is the network configuration between the WCS & MSE?
jason_majie Tue, 07/28/2009 - 17:45
I have tried rebooting the MSE with command
shutdown -r now
or manually power cycle the MSE, but still the same.
MSE and WCS are within the same ip segment, and connect to a same switch.
jason_majie Tue, 07/28/2009 - 21:10
Hi Lavramov:
My MSE version is and my WCS version is
Btw, could you tell me how to verify my license of MSE under this version?
I didn't receive any paper license (PAK)
Lucien Avramov Wed, 07/29/2009 - 08:28
5.2 still works without a license, from 6.0 you will need it.
Contacting your vendor to get a PAK. With the PAK you can get a license from TAC.
This may need further troubleshooting, I have not seen this error message before.
Trending Topics - Security & Network
