07-28-2009 12:23 AM - edited 03-04-2019 05:34 AM
Hi.
Can I configure L2TPv3 between two 2851 Routers, when the Vlan I want to pass (Vlan 22) from site to site is configured on HWIC 4 port FastEthernet on one Router and a 23 Port FastEthernet on the second Router?
The two sites are connected between then via IP over Ethernet (FastEthernet 0/1 on each Router).
My problen is the switch modules on each side.
Any idea?
Danny.
Solved! Go to Solution.
09-02-2009 05:17 AM
If you have access-vlan 18 on both F0/3 and F0/23, you aren't sending a dot1q vlan header, the frame is untagged.
The only way to send dot1q vlan headers is to configure dot1q trunking on both F0/3 and F0/23.
Both routers in the L2TPv3 configuration will forward these frames but you need to make sure both end devices (the laptops on this case) support dot1q.
__
Edison.
07-28-2009 07:18 AM
HWIC won't support the xconnect command under its fastethernet interface nor there is support for the SVI
You can attach the routed fastethernet port on the router to Vlan 22 and configure the xconnect there on each router.
With this configuration, L2/L3 traffic will transparently be sent/received between these 2 routers.
HTH,
__
Edison.
07-28-2009 11:00 PM
Hi Edison
do you mean:
interface FastEthernet 0/1.22 (interface that connects between the Rs)
no ip address
dot1q tunneling ethertype 0x9100
xconnect A.B.C.D 1 pw-class CLASS1
danny.
07-29-2009 05:08 AM
You don't need the 'dot1q' command, all you need is the xconnect.
HTH,
__
Edison.
07-29-2009 09:52 PM
Thank you.
I will try it.
Danny.
09-01-2009 05:23 AM
09-01-2009 05:39 AM
The xconnect is up and running. Per your configuration, the problem is on the switch side where you are connecting from access-vlan 18 while the router is expecting a tagged dot1q header of Vlan 18.
You need to create a trunk on the router facing interface at the switches.
09-01-2009 05:57 AM
On the 3750 inter fast 0/1 facing the router, it was configured as a trunk.
On the MATE router fast 0/2/0 was configured as trunk.
No changes were done on the ELTA router side becouse a laptop is connected directly to the switching module.
Still no connctivity between the two laptops.
What am I missing?
See drawing.
danny.
09-01-2009 06:00 AM
You only posted one switch config and it has this:
interface FastEthernet0/1
description CONNECTION TO ROUTER MATE
switchport access vlan 18
switchport mode access
speed 100
duplex full
spanning-tree portfast
I don't see any trunk configured on any of the ports.
The question is; why did you configure the xconnect under a subinterface? Make this simple, and configure the xconnect under the physical interface. It will forward all the Vlans for you end-to-end.
PS: Just looked at your diagram, you need to connect the 3750 on the MATE site directly to Port F0/1 on the router - same on the ELTA site. While the L2 Tunnel is up, your physical connection is not correct. You have to think of this as a wire between the devices and the routers are transparent. When you enable xconnect on an interface, a directly connected device on that interface will see the remote end as if they were directly connected. You can't do what you intend to do here as connecting the CE device in other ports.
___
Edison.
09-01-2009 06:12 AM
09-01-2009 06:23 AM
The problem is not the loopbacks, the problem is the physical connection. Did you read my last posting?
I understand you don't want to touch F0/0 and I see you want to use F0/1 for the inter-router link. How about using one of the switchport modules for this inter-router link:
For instance on Mate:
config#default int f0/1
to remove all configuration from F0/1
Then:
interface f0/1
no cdp enable
xconnect 5.5.5.50 1 pw-class CLASS1
interface FastEthernet0/2/1
switchport access vlan 101
vlan 101 name router-to-router_vlan
interface vlan 101
ip address 10.0.0.1 255.0.0.0
Connect the 3750 to port F0/1 on the router and that side is done.
At the ELTA site, move the inter-router link to a switchport similar to above and connect the laptop directly to F0/1 in the router. I believe for this connection you will need a crossover cable.
__
Edison.
09-01-2009 07:06 AM
Hi.
With the new configuration it works!!!
But, now i am connecting the laptops to vlan 1.
Is it possible to do the same using vlan 18 for the laptops?
Danny.
09-01-2009 07:12 AM
Please provide the new config from all devices; the 2 routers - 3750 switch as well as physical network diagram to understand these new changes.
09-01-2009 07:25 AM
09-01-2009 07:37 AM
F0/3 uplink and F0/23 on laptop is all on the 3750 side which config you have not posted.
Anyway, you can change the vlan membership from Vlan 1 to Vlan 18 on F0/3 and F0/23 and the remote laptop will be able to connect to your local laptop.
As I stated before, at this moment, your remote laptop is acting like it is directly connected to F0/3.
As long as F0/3 and F0/23 are on the same Vlan, you will be able to communicate between laptops without any routing on the 3750 switch.
If you decide to have F0/3 and F0/23 on different vlans, you need to enable routing on the 3750 switch, change the IP subnets on the default and point to their respective gateways on the 3750.
__
Edison.
Please make sure to rate helpful posts
