Distintive ring for internal and external call
Answered Question
Jul 28th, 2009
I want for each phone à distinctive ring for internal and external call.
is that possible? if yes please help.
thanks
Correct Answer by Jaime Valencia about 7 years 8 months ago
No, it just changes the cadence of the ring for calls. They're not 2 different rings.
java
if this helps, please rate
Overall Rating: 5 (1 ratings)
bsaid1977 Tue, 07/28/2009 - 06:09
hi,
cisco said in datsheet, call manager 6.1 can do that, but i can't find any doc to configure it.
all help will be very very apreciated.
thanks
Rob Huffman Tue, 07/28/2009 - 06:17
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
bsaid1977 Tue, 07/28/2009 - 06:35
i have a look at this links.
i will back to you
thank you.
bsaid1977 Tue, 07/28/2009 - 06:52
hi Rob,
the second link doesn't work.
but the first , i can see thai in datasheet. but i don't understand what they mean by "Distinctive ring (on-net vs. off-net)".
Perhaps, echc phone can give 2 different rings, one for internal call, and other for external call.
Correct Answer
Jaime Valencia Tue, 07/28/2009 - 07:37
  • Cisco Employee,
  • Hall of Fame,
    2011
java
bsaid1977 Tue, 07/28/2009 - 08:46
thank you java.
so i understand that configuring 2 differnt ring is impossible . it's right ? please confirm.
Jaime Valencia Tue, 07/28/2009 - 08:56
  • Cisco Employee,
  • Hall of Fame,
    2011
NOT possible
java
