E&M Leads signaling Suppression or disabling
Hi Folks I have Communications system which uses 4 wire for Receive and transmit the system is a dedicated or always on. We mistakenly bought E&M interface because we wanted to use it the four wires for voice transmission. In this case we see no need for signaling ? Is there any way of disabling the signaling since the system is dedicated? If not what is the other alternative?
paolo bevilacqua Tue, 07/28/2009 - 03:05
  • Hall of Fame,
    Founding Member
Yes, there is a lot of options like "signaling immediate", the details depends on what you're trying to do actually.
