MTP`s not registering
iptuser55
Level 6
Level 6
I`ve inherited a CUCM system , previously as part of the install the MTP`s were created but the IP Media Voice streaming was never turned on so the MTP`s were not registered. I`ve now turned on media streaming but the MTP`s still did not registered - any idea`s, what do I need to do ?
General question if we have a single site cluster why would you require MTP`s if everything is the same Codec - I think we need them in our case because we are using a SIP trunk on which DTMF tones are sent
thanks
8 Replies 8
Jaime Valencia
Try deleting and recreating the MTP
As you mentioned most usually MTPs are required for supplementary services on H323 or SIP trunks.
Media Termination Point (MTP)
http://www.cisco.com/en/US/docs/voice_ip_comm/cucm/srnd/7x/media.html#wp1046314
java
if this helps, please rate
java
Java,
As I mentioned I started the Media Streaming on two of the servers - Sub 1, Sub 3. So If I now delete the MTP which was created at the install on Sub 1 should be automatically register when I create it again ?
I could not delete them - there no option to do so we`re using 6.1.2.xxxx. I`ve attached a screen shoot of the MTP page on CCM- Any idea`s. If I "select all" option or the top box which normally selects anything on the page and then press enter delete selected it returned no MTP has been selected
Hi Java
I cant register the MTP the gateways are showing me this error
Software MTP Oper State: ACTIVE_IN_PROGRESS - Cause Code: TCP_CONN_ERROR
Active Call Manager: NONE
TCP Link Status: NOT_CONNECTED, Profile Identifier: 3
Reported Max Streams: 88, Reported Max OOS Streams: 0
Supported Codec: g711ulaw, Maximum Packetization Period: 30
Supported Codec: rfc2833 dtmf, Maximum Packetization Period: 30
This is my current configuration...
sccp ccm group 1
associate ccm 1 priority 1
associate profile 3 register MCKVG1-HW-AVAYA
associate profile 2 register MCKVG1-HW-CONF
associate profile 1 register MCKVG1-HW-XCODE
dspfarm profile 1 transcode
description MCKVG1-HW-XCODE
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec gsmfr
maximum sessions 12
associate application SCCP
dspfarm profile 3 mtp
description MTP H323 for AVAYA
codec g711ulaw
maximum sessions hardware 4
maximum sessions software 40
Any idea?
Andres
Make sure that the MTP definition in CM uses the correct MAC address or EXACT EXPLICIT hostname of the device providing the MTP resource. If the MTP resource is a ISR, ensure that there are no unintentional white-spaces in the hostname when you define it in CM.
What do you have for your sccp local and sccp ccm x.x.x.x commands? I don't see these here in the config. You'll need:
sccp local fa0/0
Choose the appropriate interface that the MTP will register from.
sccp ccm x.x.x.x identifier 1 priority 1 version ?
Put in the UCM ip address where the x's are and for the version, hit the ? mark and put your CM version in. If you're running version 5, 6, or 7 and the highest option available is 5.x, choose the highest available.
Please rate if this helps.
interface Loopback0
ip address 10.10.194.85 255.255.255.255
sccp local Loopback0
sccp ccm 10.11.194.5 identifier 3
sccp ccm 10.11.194.7 identifier 2
sccp ccm 10.11.194.9 identifier 1
sccp
sccp ccm group 1
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec gsmfr
maximum sessions 12
dspfarm profile 2 conference
codec g711ulaw
codec g711alaw
codec g729ar8
codec g729abr8
codec g729r8
codec g729br8
shutdown
codec g711ulaw
Try this:
no sccp
sccp ccm group 1
no associate ccm 1 pri 1
no sccp ccm 10.11.194.5 identifier 3
no sccp ccm 10.11.194.7 identifier 2
no sccp ccm 10.11.194.9 identifier 1
sccp ccm 10.11.194.5 identifier 3 ver 5.0
sccp ccm 10.11.194.7 identifier 2 ver 5.0
sccp ccm 10.11.194.9 identifier 1 ver 5.0
sccp ccm group 1
You can check to see if there is a closer version match to your actual CUCM version and use that instead of 5.0
hth,
nick
