07-28-2009 03:41 AM - edited 03-04-2019 05:34 AM
Hi All!
I have a strange problem with my C7206-VXR (IOS c7200-adventerprisek9-mz.122-33.SRD2) router: when I set up PAT inside to outside address translation using static ip+tcp mapping like "ip nat inside source static tcp ...", router sends to console this error output:
(config)#ip nat inside source static tcp 10.41.0.29 4662 x.x.x.74 4662 extendable
%Port 4662 is being used by system
(config)#ip nat inside source static tcp 10.41.0.29 4662 x.x.x.74 4661 extendable
%Port 4661 is being used by system
However, this translation is not presented in my running-config:
#sh run | i ip nat
ip nat pool 123 x.x.x.65 x.x.x.78 netmask 255.255.255.240
ip nat inside source list 181 pool 123 overload
ip nat inside source static tcp 10.41.0.254 3389 x.x.x.75 3389 extendable
ip nat inside source static tcp 10.41.0.121 50 x.x.x.77 50 extendable
ip nat inside source static tcp 10.41.0.121 51 x.x.x.77 51 extendable
ip nat inside source static udp 10.41.0.121 500 x.x.x.77 500 extendable
ip nat inside source static tcp 10.41.0.30 3389 x.x.x.78 3389 extendable
ip nat inside source static tcp 10.41.0.30 15000 x.x.x.78 15000 extendable
#sh ip nat translations
Pro Inside global Inside local Outside local Outside global
tcp x.x.x.78:3389 10.41.0.30:3389 --- ---
tcp x.x.x.78:15000 10.41.0.30:15000 --- ---
tcp x.x.x.77:50 10.41.0.121:50 --- ---
tcp x.x.x.77:51 10.41.0.121:51 --- ---
udp x.x.x.77:500 10.41.0.121:500 --- ---
tcp x.x.x.75:3389 10.41.0.254:3389 --- ---
Another interesting fact is that when I set up forwarding on another port (using the same IP addresses), it's working like it should:
(config)#ip nat inside source static tcp 10.41.0.29 4662 x.x.x.74 466 extendable
(config)#do sh ip nat trans
tcp x.x.x.74:466 10.41.0.29:4662 --- ---
As you can see, router installs translation in this case (using the same parameters but another outside TCP port - 466). I'm tried to reload the router and issued "clear ip nat translation *" command, but it's not helped me.
Any ideas to why router cannot setup static PAT translations on certain outside ports in this scheme?
I cannot find any explanation of this bug on cisco.com, maybe anyone can help me with this problem?...
P.S. This situation continues when I trying to use some UDP outside ports, for example, UDP 4500.
Thanks.
Nikita
07-28-2009 04:54 AM
Hi Nikita,
I found two bugs related to your issue:
- CSCsj29841
- CSCsu59515
You need to open a TAC case to confirm if you are hitting one of those bugs.
Laurent.
07-28-2009 09:40 PM
Thank You Laurent!
Symptoms in this bug reports is very similar to my. To my regret, our SmartNet warranty expired, so I can't open a TAC case. I will try to use another IOS version, maybe it will help.
Best regards,
Nikita
