Peter Paluch Tue, 07/28/2009 - 04:55
  • Cisco Employee,
The 2500 series have a built-in IOS sometimes called RxBoot or BootROM. You appear to be starting that IOS instead of the full version stored in the FLASH. That happens in two scenarios:
1.) The configuration register ends with '1', like 0x2101 or 0x2141. The solution here is quite simple - set the register to 0x2142 to make sure that the router shall boot the IOS from flash and to ignore any stored configuration. Then reboot and see if the router boots up properly. If yes, check the stored configuration for any configuration errors and set the configuration register to the default value 0x2102.
2.) It might be that your IOS in the FLASH is damaged or erased. In that case, you will need to restore it.
Best regards,
Peter
lucky.sanj Tue, 03/13/2012 - 23:55
Sorry same thing happening with me also..
This is my router information.
[code]
Router(boot)#show version
Cisco IOS Software, 7200 Software (C7200P-KBOOT-M), Version 12.4(4)XD5, RELEASE)
Copyright (c) 1986-2006 by Cisco Systems, Inc.
Compiled Tue 19-Dec-06 16:07 by alnguyen
ROM: System Bootstrap, Version 12.4(12.2r)T, RELEASE SOFTWARE (fc1)
Router uptime is 1 minutes
System returned to ROM by reload at 18:27:51 UTC Sat May 12 2001
System image file is "bootflash:c7200p-kboot-mz.124-4.XD5.bin"
Last reload reason: Reload Command
Cisco 7206VXR (NPE-G2) processor (revision A) with 917504K/65536K bytes of memo.
Processor board ID 18284544
MPC7448 CPU at 1666Mhz, Implementation 0, Rev 2.2
6 slot VXR midplane, Version 2.0
Last reset from power-on
PCI bus mb1 (Slots 1, 3 and 5) has a capacity of 600 bandwidth points.
Current configuration on bus mb1 has a total of 0 bandwidth points.
This configuration is within the PCI bus capacity and is supported.
PCI bus mb2 (Slots 2, 4 and 6) has a capacity of 600 bandwidth points.
Current configuration on bus mb2 has a total of 0 bandwidth points.
Please refer to the following document "Cisco 7200 Series Port Adaptor
Hardware Configuration Guidelines" on Cisco.com <http://www.cisco.com>
for c7200 bandwidth points oversubscription and usage guidelines.
1 FastEthernet interface
3 Gigabit Ethernet interfaces
2045K bytes of NVRAM.
250368K bytes of ATA PCMCIA card at slot 2 (Sector size 512 bytes).
65536K bytes of Flash internal SIMM (Sector size 512K).
Router(boot)#show version | inc im
Router uptime is 15 minutes
Router(boot)#show ver | inc NPE
Router(boot)#
[/code]
After ever time when i reboot the router i am on Router(boot)# mode. so where i am missing.
Richard Burts Wed, 03/14/2012 - 05:17
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 LAN, WAN
The output that you posted shows that the config register is 0x2102, which is correct. So that is not the problem.
The output that you posted shows that it is attempting to boot "bootflash:c7200p-kboot-mz.124-4.XD5.bin" Can you verify what is in bootflash on this router?
It might be helpful if you would reboot again, and post all the messages sent to the console during the boot process. This might point more clearly at the problem.
Rick
glen.grant Wed, 03/14/2012 - 05:37
  • Purple, 4500 points or more
     The 7200's have 2 images , one is a bootloader image which is what yours is loading for some reason .  See if the normal image is in flash and point your boot statement to that image.  If not then you will have to load a new image into flash preferrably one that is close to the bootloader image.
lucky.sanj Thu, 03/15/2012 - 02:28
Thank you so much for nice suggestion now i download valid cisco image for 7206VXR (NPE-G2) & it seems like work.
But i can't point any thing & it didn't show any error.
Thank you.
