Gateway issues
Jul 28th, 2009
About 3 weeks ago we installed a vg224 analog gateway and have some fax machines on this along with paging. Last week random ports would go dead. If we moved whatever is on that port to a new port and re configed the new port it worked fine for a few days with same result. We replaced the gateway, cable and panel associated with it and we are still experiencing the same issue. We have reset many many times.
wdrootz Mon, 08/03/2009 - 06:36
Is it initial setup or has been working since long? Did you try reloading VG224?
