CUPC Desk Phone not working
Answered Question
Hello everyone.
I am having an issue where my CUPC Client cannot connect to my deskphone. I have gone through user, and application setup and all looks fine.
I get Not Connected - Invalid credentials.
Correct Answer by htluo about 7 years 10 months ago
To use video with desk phone, you need CUVA (Cisco Unified Video Advantage).
Michael
Go to CUCM > System > LDAP > LDAP Authentication.
If you're using Active Directory authentication, use port 3268 instead of 389. Then restart CTIManager (on all CUCM servers).
Michael
http://htluo.blogspot.com
Overall Rating: 5 (3 ratings)
Correct Answer
htluo Tue, 07/28/2009 - 07:08
  • Red, 2250 points or more
Michael
vasco.tonack Tue, 10/13/2009 - 02:32
Hi Michael,
we got the same Error. When i take a look at the trace from CTIManager i get the following Errors:
CTI|Available Servers (2)|
CTI|authenticationLDAP::Authenticate():exit AUTH_NOT_INITIALIZED|
CTI|Error authentication of user for reading configuration |
CTI|authenticationLDAP::connect():Exit on Error|
CTI|Failure in LdapDeviceList::Initialize()|
CTI|authenticationLDAP::authenticateUserWithPassword():Exit on Error|
CTI|authenticationDB::login (Done Authenticating using LDAP)|
CTI|authenticationDB::login (LDAP FAILED) (-1)|
CTI|AuthenticationImpl::setResults:enter|
CTI|AuthenticationImpl::setResults retCode= -1|
CTI|AuthenticationImpl::setResults logLevel is 3|
CTI|CQBEBuilder::BuildQbeMessage(): objectID=3|
CTI|CTIHandler::OutputQbeMessage(): TcpHandle=[2:200:7:14] Qbe Prefix={0xb5e408b8,0x7a}
CTI|kCtiProviderOpenFailure - CTI application failed to open provider CTIconnectionId:14 Login User Id:myusername Reason code.:-1932787616
We are using an Openldap for Directory Synch and Authentication. It worked until we upgraded from 6.1.2 to 6.1.4. Any Idea how to troubleshoot?
The LDAP Synchronization works fine with SSL. My OpenLDAP Administrator told me that there is an corrupt SSL-Handshake in his Log at the Timestamp the CTIManager asks for Authentication.
Kind regards,
Vasco
htluo Tue, 10/13/2009 - 10:24
Are you able to log into CUCM user options page with any LDAP credentials?
I guess the LDAP certificate was lost during the upgrade. You might want to double check the "Directory-Trust" certificate in CUCM OS Administration page.
Michael
vasco.tonack Tue, 10/13/2009 - 10:28
Yes, i can login. I also double checked the LDAP Certificates. They were indeed broken, but i fixed that already. Both, Authentication and Synchronization are working. Only the CTI-Manager gives me trouble when activating the DeskPhone via CUPC.
Kind regards,
Vasco
