Is QoS implementation possible on Internet Links?
Jul 28th, 2009
Hi Folks,
I have a quick question? Is QoS implementation possible on Internet Links? If yes, what are the technical considerations need to take before implementaion. If the above details are not adequate to conclude the solution, please let me know what information is required to provide the solution.
vmiller Tue, 07/28/2009 - 08:28
  • Gold, 750 points or more
Its "possible". But of marginal use.
I's sure there are cases where customers have a qos policy to their ISP, but after that there is no means to insure that any one else will honor the QOS markings.
Joseph W. Doherty Tue, 07/28/2009 - 09:12
Answer depends on what you want to accomplish and how you plan to use your Internet links.
You can do pretty much whatever you want outbound, but beyond your router, Internet routers are out of your control.
Inbound, you're very limited what you can effectively accomplish.
With the above in mine, in some special situations you can obtain results often like what can be accomplished across a private link. For instance, if you build a VPN connection across the Internet, and don't share those Internet links for non-VPN traffic, and implement QoS configured to manage bandwidth bottleneck, performance is often much like a dedicated link. Reason for this, Internet congestion often found mostly at customer links to/from ISP.
master321 Fri, 07/31/2009 - 07:50
Thanks for replying!!!
I'd like to put more light on it.
Actually we have two Internet routers which are having two seperate links of 35 MB bandwidth to internet Service providers (SP1 and SP2) and configured load balancing the between two ISPs. We are having many client VPN traffic and client http sites which are passing through internet Links and chocking both the lines at business hours eventhough QoS policies are in place. Find below the QoS policy config for your reference and kindly suggest me for an appropriate solution to how to reduce congestion by configuring QoS on the links.
class-map match-any ACTIVE24
match access-group 140
class-map match-any Internet_Rate
match access-group name INDIA_RATE
policy-map ACTIVE24_BW_POLICING
description limiting BW for ACTIVE24 - Limelight access using port 1935
class ACTIVE24
police 7000000 conform-action transmit exceed-action drop violate-action drop
policy-map INT_RATE
class Internet_Rate
police 1536000 384000 384000 conform-action transmit exceed-action drop violate-action drop
interface Loopback0
ip address 10.1.5.1 255.255.255.255
interface FastEthernet0/0
description to Firewall
ip address 10.1.4.2 255.255.255.0
no ip redirects
no ip proxy-arp
load-interval 30
speed auto
full-duplex
no cdp enable
standby 1 ip 10.1.4.1
standby 1 timers 2 5
standby 1 priority 105
standby 1 preempt
standby 1 authentication INDIAINT12
interface FastEthernet0/1
bandwidth 35000
ip address 111.11.1.110 255.255.255.252
ip access-group SP1_INBOUND_INTERFACE_FILTER in
no ip redirects
no ip proxy-arp
ip accounting output-packets
ip flow ingress
ip flow egress
ip route-cache flow
load-interval 30
speed auto
full-duplex
no cdp enable
vmiller Fri, 07/31/2009 - 08:09
What sort of data do you have regarding link utilization?
Who manages the routers at the edge of this network?
If you do, you could consider a traffic marking scheme,
Joseph W. Doherty Fri, 07/31/2009 - 16:04
I don't see the policy-map applied.
For outbound, you might start with something like this:
policy-map QoS_policy
class class-default
fair-queue
interface fastE 0/1
service-policy outbound QoS_policy
As I noted in my prior post, inbound is a problem. You could implement some kind of policer, as in your posting, but such don't usually well keep the inbound traffic from bursting on your circuit upstream of the policer. I.e. you can control the downstream rate (from the policer), but the issue is congestion on the WAN link, which is why you ideally want QoS on the ISP side, outbound.
(BTW, I have done outbound ACK rate shaping, which can influence inbound TCP traffic rates, but tricky to get "just right".)
Don't believe Cisco has a product that addresses this issue, but 3rd party products like Packeteer's, for TCP, can.
master321 Sun, 08/02/2009 - 10:54
Thanks for your response....
As per my managers point of view for implementaion of inbound policy we need to implement QOSpolicies also on the ISP side and for that they would be charging for providing the QoS service. So keeping cost in our mind he wants me to come up with such solution that the congestion would be reduced with the implementation of outbound policy or with prioritization techniques.
Can you send me the cofiguration steps how to implement outbound policies based on the 35 MBbandwidth on the link. Your help is much appriciated for one more time.
Joseph W. Doherty Sun, 08/02/2009 - 11:21
Regarding ISP charging for inbound QoS, if the inbound bandwidth is oversubscribed, it might be a good deal. You would need to compare additional cost vs. impact of doing nothing, or and other other approaches (e.g. more bandwidth or 3rd party device).
Two techniques that can be used with effect with inbound TCP traffic to regulate their bandwidth consumption, is policing it (so packets drops slow sender rate) or shaping outbound TCP ACKs.
For outbound, again, I would start with a FQ queuing configuration. However, since you mention 35 Mbps and have shown fast Ethernet interfaces, you'll likely want to shape the traffic to the available bandwidth. This can be done using just a generic traffic shaper (which generally also implements WFQ) or using a shaper within CBWFQ (which allows you later on to prioritize different traffic differently). For Ethernet, you often need the shaper set slower than "nomimal" bandwidth to allow for L2 overhead (this depends on what the ISP is measuring).
e.g.
policy-map asample
class class-default
shape average (30 Mbps)
interface fastethernet #
service-policy output asample
or
traffic-rate rate (30 Mbps)
master321 Fri, 08/07/2009 - 18:18
Hi Joseph,
Thanks for the information.
Will look forward to implement these techniques and will let you the outcome. If have stuck in the middle then i'll again trouble you this again :-) :-)
Once again thanks for the information and looking forward to learn more on this.
