07-28-2009 09:41 AM - edited 07-03-2021 05:53 PM
Per Cisco Security Advisory ID: cisco-sa-20090727-wlc there appears to a lot of security vulnerabilities. It is recommending that upgrade my controllers to 4.2.207.0 which I have no problems in doing.
Question: Would I also need to upgrade my WCS software (firmware) as well; seeing as though the controller software will be a much newer version?
Solved! Go to Solution.
07-28-2009 10:01 AM
4.2.207.0 got released 4 days ago. There is actually no WCS version that was released after this, so there is no actual WCS version that will work 100% with this newer controller version.
If you must upgrade your controller to 4.2.207.0 you can do so, but you will loose managing ability from WCS until there is a new Maintenance Release of 4.2.x, 5.2.x or 6.0.x.
I suggest that you wait if the security advisory is not applicable to your environment.
07-28-2009 10:01 AM
07-28-2009 10:09 AM
Thanks so much Lucien for the quick turnaround and easy explanation. I will wait then.
thanks...
Jorge
08-03-2009 07:28 AM
Actually, if you read the 4.2.207.0 release notes, you will see the following:
Note Only Cisco WCS 4.2.128.0, 5.2, and 6.0 support controllers running software release 4.2.207.0.
07-28-2009 11:02 AM
Hi Lucien.
In the Cisco security advisory ID: cisco-sa-20090727-wlc there is a matrix or a table that says "first fixed version" and "Recommended Release" For the First fixed version it is recommending 4.2.205 ane the recommended release it me to install 4.2.207.
This is a bit confusing for me. does this mean if I currently have version 4.2.205 installed on my WLC's I shouldn't have anything to worry about???
07-28-2009 11:23 AM
I checked the bug listed on the advisory, you are fine with 4.2.205.0. Those bugs are fixed in that version you have.
I dont know why they have a different recommended version, probably to encourage users to upgrade for other bug fixes.
07-28-2009 12:07 PM
That's Great!!!
thanks for your help. This beats creating a tac case any day...
