3750E TD-S or TD-E for eigrp routing
Answered Question
Hi, I need to run EIGRP. In the beginning, we will just do EIGRP stub routing, so 3750E TD-S is good for us, but later we may reuse the same switch to do full EIGRP routing. My question is if we buy a 3750E-TD-S now, can we upgrade it to 3750E-TD-E for the full EIGRP routing function? Will a software IOS upgrade do that?
Thanks.
Ben
Correct Answer by Jerry Ye about 7 years 9 months ago
Hi Ben,
I believe you can use the command license boot
http://www.cisco.com/en/US/docs/switches/lan/catalyst3750e_3560e/software/release/12.2_46_se/command/reference/cli1.html#wp8991321
I cannot verify it in my lab switch.
Here is a link of the license activation commands and procedures
http://www.cisco.com/en/US/docs/ios/csa/configuration/guide/csa_commands.html#wpxref81295
HTH,
jerry
Overall Rating: 5 (1 ratings)
Thanks.
But I have colleagues tried that before, but didn't work. They said it seems to be hardware dependent.. even if they downloaded the IOS for 3750E-TD-E switch, when doing 'show version', it still showed as 'IP-Based' and only eigrp-stub routing is avilable, so I would like to confirm if that is the case, that a 3750E-TD-S cannot be upgraded to a 3750E-TD-E just by a IOS upgrade. I want to confirm that before we make the purchase. Thanks.
Jerry Ye Tue, 07/28/2009 - 10:34
  • Cisco Employee,
Hi Ben,
You can upgrade to the Enhanced image, since the 3750E-TD-S is the standard image. You will have to purchase the Enhanced image PAK from your reseller since the 3750E will require a license file.
HTH,
jerry
Jerry Ye Tue, 07/28/2009 - 10:51
  • Cisco Employee,
Hi Ben,
That is correct, the new 3750E image is called the Universal image, and software features are activated by license key.
Here is the license example
Switch#sh license all
License Store: Primary License Storage
StoreIndex: 1 Feature: advipservices Version: 1.0
License Type: Permanent
License State: Active, Not in Use
License Priority: Medium
HTH,
jerry
Jerry,
Thanks a lot for your quick response!
StoreIndex: 0 Feature: ipbase Version: 1.0
License State: Active, In Use
License Count: Non-Counted
License Store: Evaluation License Storage
StoreIndex: 0 Feature: ipservices Version: 1.0
License Type: Evaluation
License State: Active, Not in Use, EULA not accepted
Evaluation total period: 8 weeks 4 days
Evaluation period left: 8 weeks 4 days
License Priority: None
This is a capture from my colleague's 3750E, it shows that there is an evaluation 'ipservice' license for 8 weeks. Does it mean we can somehow enable the 'ipservice license' for 8 weeks for testing?
If yes, how do we enable that?
Thanks!
Ben
Correct Answer
Jerry Ye Tue, 07/28/2009 - 11:12
  • Cisco Employee,
Hi Ben,
HTH,
jerry
