Corrupted NVRAM during conversion from CatOS to IOS on 6500.
Answered Question
Jul 28th, 2009
I was following the procedures to convert CatOS to IOS on a 6500 with Sup-32. During one of the steps, after going into rommon 'priv' mode and doing a reset, it comes back with:
Warning: Rommon NVRAM is corrupted. Initialize the area to default values.
Cat6k-MSFC2A Platform
How does one initialize the are to default values? Is this a recoverable situation?
Correct Answer by Edison Ortiz about 4 years 8 months ago
Jim,
I've seen that error before and before opening a TAC case and requesting for a RMA, can you try putting the Supervisor in another slot?
HTH,
__
Edison.
Average Rating: 5 (1 ratings)
jbrenesj Tue, 07/28/2009 - 11:35
This is normally not good...
Try to re-purge the NVRAM from rommon if it lets you do it before it reloads again, if not, I was once able to put back the CatOS on it and re-did the conversion procedure. If not, RMA
rommon 2 > priv
!--- Press Enter or Return.
!--- You have entered ROMmon privileged mode.
!--- You see this output:
You now have access to the full set of monitor commands.
Warning: some commands will allow you to destroy your
configuration and/or system images and could render
the machine unbootable.
rommon 3 > fill
!--- Be sure to enter these parameters exactly:
!--- The first line is a "be" (no space) followed by six zeros ("000000").
!--- The next line is an "8" (no space) followed by four zeros ("0000").
Enter in hex the start address [0x0]: be000000
Enter in hex the test size or length in bytes [0x0]: 80000
Enter in hex the pattern to be written [0x0]: ffff
Enter the operation size 'l'ong, 'w'ord, or 'b'yte []: l
!--- After the NVRAM erase has completed, issue the reset command.
rommon 4 > reset
System Bootstrap, Version 12.2(17r)SX3, RELEASE SOFTWARE(fc1)
Copyright(c) 2004 by cisco Systems, Inc.
!--- Output suppressed.
jkeeffe Tue, 07/28/2009 - 11:50
I'll try that once again - but that is how this all started. I went through the procedure:
be000000
80000
ffff
l
reset
.....and it was when the system started to reset that the error message popped up.
How did you get CatOS back on? Probably through a procedure as grueling as converting to IOS?
jbrenesj Tue, 07/28/2009 - 11:59
If you have the catos .bin file either on bootdisk: or disk0: you can try to load it from rommon.
rommon>dir (bootdisk: | disk0:)
rommon>boot (put the path here)
It sometimes work depending on the progress made on the conversion process.
Correct Answer
Edison Ortiz Tue, 07/28/2009 - 12:04
Jim,
HTH,
__
Edison.
jkeeffe Tue, 07/28/2009 - 12:36
Edison - you're the magic man today with that solution! I moved the sup to another slot and it booted to IOS perfectly. Then I moved it back and the same. All is well - thanks!
jkeeffe Tue, 07/28/2009 - 12:59
This was in a 6503-E and the sup-32 was in slot 1. Then I moved it to slot 2 at Edisons suggestion. Now it is back in slot 1.
Login or Register to take actions
Posted July 28, 2009 at 11:08 AM
Stats:
Replies:8 Avg. Rating:5
Views:1401 Votes:0
Shares:0
Tags: No tags.
Discussions Leaderboard
Rank Username Points
1 14,997
2 8,150
3 7,720
4 7,083
5 6,723
175
80
60
59
55
