Wake-On-LAN to subinterfaces on an ASA 5540
Jul 28th, 2009
I want to get Wake-On-Lan working across subinterfaces on an ASA 5540. I currently have a layer 2 switch with a trunk port to the ASA. That ASA interface contains all the subinterfaces. On a layer 3 switch I would create an access-list permiting the WOL server and then apply the "ip directed-broadcast <access-list>" on each VLAN. The subinterfaces on the ASA don't support that command. Is there a way to do this on an ASA?
Overall Rating: 5 (1 ratings)
brianhill88 Tue, 08/04/2009 - 17:04
I found out that ip directed-broadcast is the default. You don't have to change anything.
suschoud Tue, 08/04/2009 - 17:11
  • Gold, 750 points or more
In PIX,6.x versions we used to pass directed broadcast traffic through PIX. However, this changed in 7.x. Later a defect was filed do revert back the behavior to pass directed broadcast through ASA/PIX (CSCsc37965). If you are running a image which has a fix for this bug, you should be able to pass "directed" broadcast through ASA. There is no command required to make this work.
Use bug toolkit within cisco.com to find what images fixed the above mentioned bug.
hTH
Sushil
