ICM/IPCCE EDMT tool upgrade failed
Jul 28th, 2009
All,
Anyone use EDMT to upgrade ICM6.0 to ICM7.0 and ICM7.5.
It seems be pre-mature for Cisco EDMT (extended data migration tool). Tried to use EDMT to upgrade ICM6.0 to ICM7.0, but it failed and showed error like:
table 't_routing_script' has none syslink (forget the exact error msg) but it just indicate the two tables have error.
Also, we saw and fixed another error msgs (like: duplate username due to case sensitive, ie, MarkL = markl). Removed one user from tables and got EDMT ongoing..
However, now we faced another error msg during EDMT migration.
Anyone have thoughts with such error msg with EDMT and how to bypass?
Your input are appreciated!
Overall Rating: 3 (1 ratings)
jamesfang98 Wed, 07/29/2009 - 08:17
Fixed byself.
For whom may be interested:
Restore SQL DB data from production server to new ICM server, then re-run EDMT and it works.
More likely, the EDMT process hangup or corrupt at some certain points. So re-do the process fixed the issues.
