Auto answering/line select for 7961G
Answered Question
Jul 28th, 2009
Is it possible to have a line on a 7961G other than line 1 and not answer it upon picking up the handset? I just want to monitor the line and have it available for CallREC. I've tried making changes to the "Auto Line Select" & "Auto Call Select" fields with no changes.
Thanks -SC
Correct Answer by Rob Huffman about 7 years 11 months ago
Hi Stephen,
Excellent question here. Have a look at this setting the config behaviour has changed with the release of CUCM 6.1(3), have a look;
Always Use Prime Line = True for your scenario
Tip The information in this section does not exist in the online help for Cisco Unified Communications Manager Administration or in any other Cisco Unified Communications Manager 6.1(x) document besides the release notes.
Description
After you configure the Always Use Prime Line setting in Cisco Unified Communications Manager Administration, when the phone is idle (off hook) and receives a call on any line, the primary line gets chosen for the call.
Tip To configure the Always Use Prime Line feature in previous releases of Cisco Unified Communications Manager, you configured the Always Use Prime Line service parameter for the Cisco CallManager service. In Cisco Unified Communications Manager 6.1(3), you can configure the Always Use Prime Line setting for devices and device profiles.
Cisco Unified Communications Manager Administration Configuration Tips
When you configure this feature, going off hook makes only the first line active, even when a call rings on another line on the phone; that is, the call does not get answered on that line. In this case, the phone user must choose the other line to answer the call.
For more configuration considerations, see Table 4.
GUI Changes
The Always Use Prime Line for Voice Message setting displays in the following windows in Cisco Unified Communications Manager Administration.
•System > Service Parameters (for Cisco CallManager service)
•Device > Phone
•Device > Common Phone Profile
•Device > Device Settings > Default Device Profile
•Device > Device Settings > Device Profile
Tip If you configure the Always Use Prime Line setting in the Service Parameter, Common Phone Profile, and in the Phone Configuration window, Cisco Unified Communications Manager uses the configuration from the Phone Configuration window.
http://www.cisco.com/en/US/docs/voice_ip_comm/cucmbe/rel_notes/6_1_3/cucmbe-rel_note-613.html#wp471834
Hope this helps!
Rob
Overall Rating: 5 (1 ratings)
stephencan2 Tue, 07/28/2009 - 12:27
Thanks Teresa,
The lines that I need available for recording are also the main extension for end users in the same office. Setting their line for auto-answer might cause a problem with interoffice dialing. My concern was setting the line to a silent ring so I can generally ignore it, and accidentally answering it when it rings if my handset or speaker phone goes off hook. Is there a way to force the user to choose a line before the phone goes off hook?
thanks again,
stephen
Correct Answer
Rob Huffman Tue, 07/28/2009 - 12:36
  • Hall of Fame,
    Founding Member
  • Cisco Designated VIP,
    2017 IP Telephony, Unified Communications
Hi Stephen,
Description
GUI Changes
•Device > Phone
Hope this helps!
Rob
