"voicemail callerid" command not recognized
Answered Question
Jul 28th, 2009
Cisco Unity Express Version 3.1
OS: C2800NM
IOS Software: C2800NM-SPSERVICESK9-M
Software: 12.4(15)T1 / CME 4.1(0)
Trying to enable external voicemail caller ID.
"Play caller ID for external callers" is already set to Yes. When I tried to enter the command "voicemail callerid" into the global configuration, I get an invalid input. My current email voicemail notification 'from' line are coming as "undefined". Am I missing something or do I need to upgrade my IOS?
Correct Answer by Brandon Buffin about 7 years 5 months ago
Are you using the command line for CUE. The commands would be something similar to(depending on your CUE module/slot):
router#service-module service-engine 0/0 session
cue>enable
cue#conf t
cue(config)#voicemail callerid
Hope this helps.
Brandon
Overall Rating: 5 (1 ratings)
Correct Answer
Brandon Buffin Tue, 07/28/2009 - 12:27
cue>enable
cue#conf t
Hope this helps.
Brandon
