Point to Point
Jul 28th, 2009
On a point to point connection on the serial interface when I do a show service-module I am getting:
Transmitter is sending remote alarm.
Receiver has loss of signal, loss of frame,
Framing is ESF, Line Code is B8ZS, Current clock source is line,
Does this look like a Telco problem or a config problem? CUrrently the serial interface has an IP address but is showing down/down even after a no shut.
Thanks in advance. ALl replies rated!
Overall Rating: 5 (1 ratings)
pciaccio Tue, 07/28/2009 - 12:38
  • Silver, 250 points or more
This indication is telling you that you are not seeing any signal input to the router. You probably have a wiring issue from the telco demarc point (handoff) to your router T-1 interface. I would verify connectivity on your infrastructure...
