Location server
Jul 28th, 2009
Folks,
I just setup a location sever. went through the setup tool and setup the hostname and ip address, etc.
When i go to WCS and try to import the location server, it using account admin/admin and trying to connect at port 8001 to the location server by default.
In my case wcs fails to connect to locatin server, what can i do to fix the problem.
NAVIN PARWAL Tue, 07/28/2009 - 21:39
I am running the following now and I get the same error, please help.
Version 4.2.128.0 - wcs server
3.1.43.0 -location server
NAVIN PARWAL Wed, 07/29/2009 - 01:45
The WCS is trying to connect to the location server using account admin/admin, and at port 8001, but can not connect with these credidentials, I can ping between the two and also can ssh into the location sever.
Lucien Avramov Wed, 07/29/2009 - 07:55
-admin/admin are the default credentials, if you have a doubt, you want to re-run the setup from the installers folder
-Try with https instead of http and also make sure port 8001 is not blocked. Do a netstat -an on the location to make sure it's listening on those ports
-Delete and re add the location on WCS
Trending Topics - Security & Network
