http to pix 6.3 (5) not working
Jul 28th, 2009
hi
I (10.32..64.168) can SSH into PIX but cannot HTTP into it ? I have added "http server enable" and http 10.32.0.0 255.255.252.0 inside"
inside ip of PIX =ip address inside 10.32.0.5 255.255.252.0
Ivan Martinon Tue, 07/28/2009 - 12:59
  • Cisco Employee,
Do you see anything on the logs? Can you try using http 0 0 inside instead of the statement you use and try again
CCDECCDE9 Tue, 07/28/2009 - 13:13
tried..not working
i do not see anything in logs..
pixfirewall# sh flash
flash file system: version:3 magic:0x12345679
file 0: origin: 0 length:1978424
file 1: origin: 2097152 length:44984
file 2: origin: 2228224 length:1914
file 3: origin: 0 length:0
file 4: origin: 0 length:0
file 5: origin:16646144 length:308
filter url http 0.0.0.0 0.0.0.0 0.0.0.0 0.0.0.0 allow
http server enable
http 0.0.0.0 0.0.0.0 inside
Ivan Martinon Tue, 07/28/2009 - 13:16
  • Cisco Employee,
What about:
logging on
logging buffered 7
try your http connection to the pix and then do a "show log" do you see anything for the ip address you are coming from?
Go ahead and run captures on the inside and see if the asa sends any weird packet.
Have you tried regenerating the rsa key?
Ivan Martinon Tue, 07/28/2009 - 13:24
  • Cisco Employee,
Yes, so? captures and log are the same on the pix/asa
CCDECCDE9 Tue, 07/28/2009 - 14:22
PDM is not installed in it,can I still http into it ?
