Nexus VTY Control
Answered Question
Jul 28th, 2009
How can you restrict SSH access to a Nexus except from a specific subnet? i know how to do this on an IOS device but don't see the access-class statement on the Nexus.
TIA
Correct Answer by Jerry Ye about 7 years 11 months ago
Hi Bruce,
You can allow SNMP and HTTPS via CoPP. You can check out the following example
ip access-list copp-system-acl-allow
10 remark ### ALLOW SSH
20 permit tcp 10.10.10.0/24 any eq 22
30 remark ### ALLOW SNMP
40 permit udp 10.10.20.0/24 any eq snmp
... (to include snmp, NTP, TACACS+, etc)
ip access-list copp-system-acl-deny
10 remark ### this is a catch-all to match any other traffic
20 permit ip any any
class-map type control-plane match-any copp-system-class-management-allow
match access-group name copp-system-acl-allow
class-map type control-plane match-any copp-system-class-management-deny
match access-group name copp-system-acl-deny
policy-map type control-plane copp-system-policy
class copp-system-class-management-allow
police cir 60000 kbps bc 250 ms conform transmit violate drop
class copp-system-class-management-deny
police cir 60000 kbps bc 250 ms conform drop violate drop
control-plane
service-policy input copp-system-policy
HTH,
jerry
Overall Rating: 5 (2 ratings)
Jerry Ye Tue, 07/28/2009 - 14:00
  • Cisco Employee,
Hi Bruce,
You have to apply the ACL in interface mgmt 0
N7010(config)# interface mgmt 0
N7010-1-Pod2(config-if)# ip ?
access-group Specify access control for packets
address Configure IP address on interface
HTH,
jerry
bs6825 Tue, 07/28/2009 - 14:03
Will this control SSH to any interface on the box? Do I need to configure this in every VDC or just default?
Jerry Ye Tue, 07/28/2009 - 14:39
  • Cisco Employee,
Hi Bruce,
Just verified it, you can only control the outbound traffic with the command ip access-group in interface mgmt 0.
In order to control SSH to vty like IOS, you have to configure CoPP in the default VDC. There is an enhanced bug filed to correct this problem in the later release - CSCsq20638.
Sorry for the confusion.
jerry
bs6825 Mon, 08/03/2009 - 08:16
I tried messing around with COPP with no luck. Any other thoughts?
Also, Are there ways to similarly restrict SNMP and HTTPS access to a selected group of hosts/networks?
Correct Answer
Jerry Ye Mon, 08/03/2009 - 13:03
  • Cisco Employee,
Hi Bruce,
control-plane
HTH,
jerry
bs6825 Wed, 08/05/2009 - 08:30
Thanks, I have made this work. One caveat, it only protects regular layer 3 interfaces, not the mgmt0 interface.
