strange vty/telnet problem
Jul 28th, 2009
Hi - I've just noticed a strange problem that's occurring on our network. However, I believe that it's a fairly new problem.
Some of our switches are not allowing concurrent telnet connections to their vty lines. This is in spite of having multiple lines configured and available.
The problem only occurs with telnet; multiple ssh sessions are successful. 'show users' shows that I'm the only person connected and that I'm using the first vty line.
Any ideas would be appreciated. Unfortunately, googling 'telnet' and 'problem' yielded too many results ;-)
Chris
jbrenesj Tue, 07/28/2009 - 14:49
  • Silver, 250 points or more
We need some more info.
Enable the "terminal monitor" so we can see some outputs, run a "sh tcp statistics"
1. then do a "debug ip tcp transactions",
2. try to telnet to an affected switch, capture the debugs and also
3. run these commands:
- sh tcp brief
- sh tcp statistics
- sh line
gcdudley Tue, 07/28/2009 - 15:00
Here is one more piece of info - sorry for not including it earlier - once the 1st session is established, the second attempt will receive a login prompt that immediately times out.
Such as:
telnet hostname
Trying xxx.xxx.xxx.xxx...
Connected to hostname.
Escape character is '^]'.
User Access Verification
Username:
Username:
Username: Connection to hostname closed by foreign host.
gcdudley Tue, 07/28/2009 - 15:03
The following was gathered during a failed 2nd attempt:
TCP special event debugging is on
hostname#
Jul 28 15:52:33.810: TCP0: state was LISTEN -> SYNRCVD [23 -> xxx.xxx.xxx.xxx0(54964)]
Jul 28 15:52:33.810: TCP0: tcb 2BDE714 connection to xxx.xxx.xxx.xxx:54964, received MSS 1460, MSS is 516
Jul 28 15:52:33.810: TCP0: Connection to xxx.xxx.xxx.xxx:54964, ignoring option 3
Jul 28 15:52:33.810: TCP: sending SYN, seq 2825390698, ack 2279829130
Jul 28 15:52:33.810: TCP0: Connection to xxx.xxx.xxx.xxx:54964, advertising MSS 536
Jul 28 15:52:33.810: TCP0: state was SYNRCVD -> ESTAB [23 -> xxx.xxx.xxx.xxx(54964)]
Jul 28 15:52:33.810: TCB02BDE714 setting property TCP_TOS (1) 1C255C4
Jul 28 15:52:35.932: TCP2: state was ESTAB -> FINWAIT1 [23 -> xxx.xxx.xxx.xxx(54964)]
Jul 28 15:52:35.932: TCP2: sending FIN
Jul 28 15:52:35.932: TCP2: state was FINWAIT1 -> FINWAIT2 [23 -> xxx.xxx.xxx.xxx(54964)]
Jul 28 15:52:35.932: TCP2: FIN processed
Jul 28 15:52:35.932: TCP2: state was FINWAIT2 -> TIMEWAIT [23 -> 137.131.20.80(54964)]
cTPC77-3a#u all
Jul 28 15:52:52.944: TCP2: state was TIMEWAIT -> CLOSED [23 -> xxx.xxx.xxx.xxx(41052)]
Jul 28 15:52:52.944: TCB 0x2BA37BC destroyed
gcdudley Tue, 07/28/2009 - 19:44
1 more thing - those 3 "Username" prompts occur immediately and do not accept input - type telnet hostname and BAM - the door is shut
gcdudley Tue, 07/28/2009 - 15:07
After 1st login (successful)
sho tcp brief
TCB Local Address Foreign Address (state)
02C40020 switch.hostname.23 telnet.client..56768 ESTAB
After 2nd login attempt (failed)
switch.hostname#sho tcp brief
032A5D34 switch.hostname.23 telnet.client..62662 TIMEWAIT
sho tcp statistics
Rcvd: 175617 Total, 4990 no port
0 checksum error, 0 bad offset, 0 too short
63947 packets (758682 bytes) in sequence
2891 dup packets (260489 bytes)
20 partially dup packets (126 bytes)
0 out-of-order packets (0 bytes)
0 packets (0 bytes) with data after window
0 packets after close
0 window probe packets, 7 window update packets
320 dup ack packets, 0 ack packets with unsend data
108169 ack packets (9195786 bytes)
Sent: 187602 Total, 0 urgent packets
3964 control packets (including 17 retransmitted)
168700 data packets (9226310 bytes)
310 data packets (29413 bytes) retransmitted
5 data packets (591 bytes) fastretransmitted
14625 ack only packets (9704 delayed)
0 window probe packets, 2 window update packets
16 Connections initiated, 2546 connections accepted, 2562 connections established
2565 Connections closed (including 1302 dropped, 1 embryonic dropped)
327 Total rxmt timeout, 0 connections dropped in rxmt timeout
0 Keepalive timeout, 0 keepalive probe, 0 Connections dropped in keepalive
gcdudley Tue, 07/28/2009 - 15:09
Line 1 increments on 2nd attempt; I'm on line 0
sho line
Tty Typ Tx/Rx A Modem Roty AccO AccI Uses Noise Overruns Int
0 CTY - - - - - 5 0 0/0 -
* 1 VTY - - - 1 1 1351 0 0/0 -
2 VTY - - - - 1 1095 0 0/0 -
3 VTY - - - - 1 105 0 0/0 -
4 VTY - - - - 1 4 0 0/0 -
5 VTY - - - - 1 3 0 0/0 -
6 VTY - - - - 1 0 0 0/0 -
7 VTY - - - - 1 0 0 0/0 -
8 VTY - - - - 1 0 0 0/0 -
9 VTY - - - - 1 0 0 0/0 -
10 VTY - - - - 1 0 0 0/0 -
11 VTY - - - - 1 0 0 0/0 -
12 VTY - - - - 1 0 0 0/0 -
13 VTY - - - - 1 0 0 0/0 -
14 VTY - - - - 1 0 0 0/0 -
15 VTY - - - - 1 0 0 0/0 -
16 VTY - - - - 1 0 0 0/0 -
jbrenesj Tue, 07/28/2009 - 15:25
I just did the same thing. My PC is 10.198.39.76 and I let the telnet prompt timeout when it was asking me for the password but as you can see it waited 1 1/2 minutes before ESTAB -> FINWAIT1
In your case, this happened 2 seconds after getting to ESTAB.
Core3560#deb ip tcp transactions
Core3560#term mon
Core3560#
000652: *Mar 15 02:10:29.903: TPA: Reserved port 0 in Transport Port Agent fo
CP IP type 1
000653: *Mar 15 02:10:29.903: TPA: Released port 0 in Transport Port Agent fo
CP IP
pe 1
000654: *Mar 15 02:10:29.903: TPA: Reserved port 23 in Transport Port Agent f
TCP IP type 1
000655: *Mar 15 02:10:29.903: TCP0: state was LISTEN -> SYNRCVD [23 -> 10.198
.76(2304)]
000656: *Mar 15 02:10:29.903: TCP0: tcb 38EFA3C connection to 10.198.39.76:23
received MSS 1260, MSS is 516
000657: *Mar 15 02:10:29.903: TCP: sending SYN, seq 3749767707, ack 567419721
000658: *Mar 15 02:10:29.903: TCP0: Connection to 10.198.39.76:2304, advertis
MSS 1260
000659: *Mar 15 02:10:29.903: TCP0: state was SYNRCVD -> ESTAB [23 -> 10.198.
76(2304)]
000660: *Mar 15 02:10:29.912: TCB038EFA3C setting property TCP_TOS (1) 2323E5
000661: *Mar 15 02:12:02.958: TCP2: state was ESTAB -> FINWAIT1 [23 -> 10.198
.76(2304)]
000662: *Mar 15 02:12:02.958: TCP2: sending FIN
000663: *Mar 15 02:12:02.958: TCP2: state was FINWAIT1 -> FINWAIT2 [23 -> 10.
.39.76(2304)]
000664: *Mar 15 02:12:02.958: TCP2: FIN processed
000665: *Mar 15 02:12:02.958: TCP2: state was FINWAIT2 -> TIMEWAIT [23 -> 10.
.39.76(2304)]
000666: *Mar 15 02:13:02.962: TCP2: state was TIMEWAIT -> CLOSED [23 -> 10.19
9.76(2304)]
000667: *Mar 15 02:13:02.962: TPA: Released port 23 in Transport Port Agent f
TCP IP
pe 1
000668: *Mar 15 02:13:02.962: TCB 0x38EFA3C destroyed
I will investigate further but what is the config under vty? do you have radius/tacacs? Any special settings?
Maybe send a sh line vty 2
jbrenesj Tue, 07/28/2009 - 15:31
The switch model + IOS could help as well
gcdudley Tue, 07/28/2009 - 19:29
the problem has occurred on 3560Gs and 3750s (24 port/48 port/12 port sfp) and it doesn't happen consistently. I just tried it on 2 switches that both had problems earlier today - this time around the problem occurred on only 1.
gcdudley Tue, 07/28/2009 - 19:33
Nope, no special configs - login is local, access list allows our major network and lines 5-15 are disabled.
line vty 0 4
access-class 1 in
exec-timeout 20 0
password 7 PASSWORD
login local
Leo Laohoo Tue, 07/28/2009 - 17:36
  • Hall of Fame,
    The Hall of Fame designation is a lifetime achievement award based on significant overall achievements in the community.
  • Cisco Designated VIP,
    2017 LAN, Wireless
Hi Chris,
What's your Telnet config? Can you post the outputs for "sh run | b line vty"?
gcdudley Tue, 07/28/2009 - 19:25
line vty 0 4
access-class 1 in
exec-timeout 20 0
password 7 PASSWORD
login local
lines 5-15 do not have login allowed
the access list just allows our major network
