jbrenesj Tue, 07/28/2009 - 15:57
Yes, that is the best way but I want to add that you can actually check most of the commands for a stack member itself.
From the master:
remote command
Example:
C3750-Stack#remote command 2 show ver
C3750-Stack#remote command 2 shoe boot
Leo Laohoo Tue, 07/28/2009 - 18:41
"sh ver" and look for "System serial number" line.
"sh inventory"
kathegaj2 Wed, 07/29/2009 - 05:32
First, thanks to everyone that answered me, it feels effective when you get some kind of answer.
So, nothing in reports that can assist with inventory-ing serial numbers for equipment rather than loopback management.
I have built Netshow jobs that run sh ver | inc System serial and sh diag | inc PCB and in a large environment these are sloppy to parse.
I checked also Contract Status and these also just apply to the master serial.
Any other ideas?
adery6300 Mon, 11/23/2009 - 08:29
Any other ideas?
You need to create a Custom Report Template in RME Reports.
- Association : don't pick anything
- Inventory Group : Chassis
- Attribute : Chassis Serial Number
- Operator : Contains
- Value : All
Click "Add", then "Save Changes", then Finish.
Then you use your custom report on a selection of device (using Report Generator, Inventory, pick your custom template), and you should be good to go. I then export it to CSV for further editing, sorting, etc.
HTH.
Alex.
