site-to-site VPN | 857 Integrated Router
Jul 28th, 2009
Hi everybody,
I am looking to establish a site-to-site VPN connection with a client.  I have looked at the manual but it has not worked.
We have an 857 Integrated Router on our end which handles the PPPoE and NATs several internal devices to public IPs provided by our DSL service.
I have a provided a sh run prior to any VPN configuration.  Below the sh run are the connection settings...
If someone could provide the CLI commands, I would appreciate it.  Again, I understand the manual provides commands but I'm unsure of which commands are necessary.
Current configuration : 1917 bytes
version 12.4
no service pad
hostname @#$#$(&
boot-start-marker
boot-end-marker
enable secret 5 $1$WOv/$3DWqFFkG5GU.ZlPfy7nHJ1
aaa new-model
aaa session-id common
dot11 syslog
no ip dhcp use vrf connected
ip dhcp excluded-address 10.0.0.1 10.0.0.49
ip dhcp pool alpha
   import all
   network 10.0.0.0 255.255.255.0
   default-router 10.0.0.1
   dns-server @#$#$(& @#$#$(&
   domain-name @#$#$(&
   lease 2
ip cef
no ip domain lookup
ip domain name @#$#$(&
username @#$#$(& password 0 @#$#$(&
archive
log config
  hidekeys
ip ssh time-out 60
ip ssh authentication-retries 2
interface ATM0
no ip address
no atm ilmi-keepalive
dsl operating-mode auto
interface ATM0.1 point-to-point
pvc 0/35
  pppoe-client dial-pool-number 1
interface FastEthernet0
interface FastEthernet1
interface FastEthernet2
interface FastEthernet3
interface Vlan1
ip address 10.0.0.1 255.255.255.0
ip nat inside
ip virtual-reassembly
ip tcp adjust-mss 1412
interface Dialer0
ip address @#$#$(& 255.255.255.248
ip mtu 1452
ip nat outside
encapsulation ppp
dialer pool 1
dialer-group 1
ppp authentication pap callin
ppp pap sent-username @#$#$(& password 0 @#$#$(&
ip forward-protocol nd
ip route 0.0.0.0 0.0.0.0 Dialer0
no ip http server
no ip http secure-server
ip nat inside source list 1 interface Dialer0 overload
ip nat inside source static 10.0.0.3 @#$#$(&
ip nat inside source static 10.0.0.5 @#$#$(&
access-list 1 remark SDM_ACL Category=2
access-list 1 permit 10.0.0.0 0.0.0.255
dialer-list 1 protocol ip permit
control-plane
line con 0
no modem enable
line aux 0
line vty 0 4
transport input ssh
scheduler max-task-time 5000
end
(IPs adjusted for privacy)
He asked that we have our internal IP space NAT to 10.20.30.40 /32
They use the following:
3DES MDS
Group 2
VPN peer IP: 60.70.80.90
Thanks in advance!
Peter K.
NVT
Related Content
