show controllers "transmit ring"
Jul 28th, 2009
I am having some trouble with a T1 between a Cisco 1721 router with a WIC-1T and a remote T1 router.
The provider is saying that everything is fine, but the show controller outpout looks strange, and I was looking to get some feedback on the "tranmit ring" section and what it indicates.
Interface Serial1
Hardware is PowerQUICC MPC860 with Integrated FT1 CSU/DSU module
TX and RX clocks detected.
idb at 0x8173A68C, driver data structure at 0x81742428
SCC Registers:
General [GSMR]=0x2:0x00000030, Protocol-specific [PSMR]=0x8
Events [SCCE]=0x0300, Mask [SCCM]=0x001F, Status [SCCS]=0x03
Transmit on Demand [TODR]=0x0, Data Sync [DSR]=0x7E7E
Interrupt Registers:
Config [CICR]=0x00365F80, Pending [CIPR]=0x04008800
Mask [CIMR]=0x60204400, In-srv [CISR]=0x00000000
Command register [CR]=0x640
Port A [PADIR]=0x0000, [PAPAR]=0x0F0F
[PAODR]=0x0000, [PADAT]=0xE1FF
Port B [PBDIR]=0x0380F, [PBPAR]=0x0C00E
[PBODR]=0x00000, [PBDAT]=0x3075C
Port C [PCDIR]=0x008, [PCPAR]=0x000
[PCSO]=0x0A0, [PCDAT]=0xFC6, [PCINT]=0x000
Receive Ring
rmd(FF002530): status 9000 length 60C address 3819D04
rmd(FF002538): status 9000 length 60C address 3817C84
rmd(FF002540): status 9000 length 60C address 3815584
rmd(FF002548): status 9000 length 60C address 381AA04
rmd(FF002550): status 9000 length 60C address 3813B84
rmd(FF002558): status 9000 length 60C address 3816284
rmd(FF002560): status 9000 length 60C address 3813504
rmd(FF002568): status 9000 length 60C address 3816904
rmd(FF002570): status 9000 length 60C address 381A384
rmd(FF002578): status 9000 length 60C address 3818984
rmd(FF002580): status 9000 length 60C address 3814204
rmd(FF002588): status 9000 length 60C address 3811B04
rmd(FF002590): status 9000 length 60C address 3814884
rmd(FF002598): status 9000 length 60C address 3819684
rmd(FF0025A0): status 9000 length 60C address 3812E84
rmd(FF0025A8): status B000 length 60C address 3816F84
Transmit Ring
tmd(FF0025B0): status 0 length 2C address 0
tmd(FF0025B8): status 0 length 2C address 0
tmd(FF0025C0): status 0 length 34 address 0
tmd(FF0025C8): status 0 length 2C address 0
tmd(FF0025D0): status 0 length 5E0 address 0
tmd(FF0025D8): status 0 length 5E0 address 0
tmd(FF0025E0): status 0 length 5E0 address 0
tmd(FF0025E8): status 0 length 5E0 address 0
tmd(FF0025F0): status 0 length 2E address 0
tmd(FF0025F8): status 0 length 2C address 0
tmd(FF002600): status 0 length 2C address 0
tmd(FF002608): status 0 length 5E0 address 0
tmd(FF002610): status 0 length 5E0 address 0
tmd(FF002618): status 0 length 5E0 address 0
tmd(FF002620): status 0 length 5E0 address 0
tmd(FF002628): status 2000 length 2E address 0
tx_limited=1(2)
SCC GENERAL PARAMETER RAM (at 0xFF003D00)
Rx BD Base [RBASE]=0x2530, Fn Code [RFCR]=0x18
Tx BD Base [TBASE]=0x25B0, Fn Code [TFCR]=0x18
Max Rx Buff Len [MRBLR]=1548
Rx State [RSTATE]=0x0, BD Ptr [RBPTR]=0x2530
Tx State [TSTATE]=0x0, BD Ptr [TBPTR]=0x25B0
SCC HDLC PARAMETER RAM (at 0xFF003D38)
CRC Preset [C_PRES]=0xFFFF, Mask [C_MASK]=0xF0B8
Errors: CRC [CRCEC]=0, Aborts [ABTSC]=0, Discards [DISFC]=0
Nonmatch Addr Cntr [NMARC]=0
Retry Count [RETRC]=0
Max Frame Length [MFLR]=1608
Rx Int Threshold [RFTHR]=0, Frame Cnt [RFCNT]=1585
User-defined Address 0000/0000/0000/0000
User-defined Address Mask 0x0000
buffer size 1524
PowerQUICC SCC specific errors:
17835 input aborts on receiving flag sequence
0 throttles, 0 enables
0 overruns
0 transmitter underruns
0 transmitter CTS losts
Peter Paluch Wed, 07/29/2009 - 00:36
Jason,
Can you perhaps be more specific about the problems you are currently having with that interface?
Best regards,
Peter
Jasonch518_2 Wed, 07/29/2009 - 05:22
Sure,
The problem was that we could not get the interface to come up.
We actually ended up re-seating the WIC, which fixed the issue, oddly enough, since it seemed to be in just fine.
I was really just wondering what information can be identified from the transmit and receive ring data.
Thanks for the reply.
