AP IOS upgrade and can't associate ?
Jul 28th, 2009
Hi NetPro,
After IOS upgrade , this AP can not Associate anymore.
Previous IOS version : flash:/c1240-k9w7-mx.123-7.JA5/c1240-k9w7-mx.123-7.JA5
Proposed IOS Version : c1240-k9w7-tar.124-10b.JDA3.tar
AP Model : AIR-AP1242AG-E-K9
BVI1 10.68.151.15 YES NVRAM up up
Dot11Radio0 unassigned YES NVRAM initializing down
FastEthernet0 unassigned YES NVRAM up up
P/S : Radio keep initializing status .
your reply will be highly appreciated.
thanks a lot.
Jack
Overall Rating: 3.5 (2 ratings)
dancampb Wed, 07/29/2009 - 07:01
Looks like the radio firmware didn't get loaded correctly. Try manually reloading the firmware with the following command:
dot11 dot11Radio 0 recovery-fw flash:c1240-k9w7-mx.124-10b.JDA3/6701.img
Then reload the entire image again. If that doesn't do the trick you'll probably need to RMA the AP.
Trending Topics: Other Wireless Mobility
client could not be authenticated
Network Analysis Module (NAM) Products
Cisco 6500 nam
reason 440 driver failure
Cisco password cracker
Cisco Wireless mode
