Campus Manager Port VLAN Assignment
Answered Question
Jul 28th, 2009
Hi All,
Is there a way to configure a port for :
switch(config-if)# switchport trunk native vlan xx
using the port VLAN assigment in the LMS Campus Manager ?
Correct Answer by Joe Clarke about 7 years 6 months ago
If the port is already trunking, then the way to do this is with RME's Netconfig. If you have LMS 3.2, this is even easier since Netconfig includes a port-based template system. However, even with LMS 3.1 and earlier, you can create an Adhoc job to deploy this command to a given switchport.
VLAN Port Assignments can only be used on access ports.
Overall Rating: 5 (1 ratings)
Correct Answer
Joe Clarke Tue, 07/28/2009 - 22:00
