07-28-2009 10:04 PM - edited 03-15-2019 07:07 PM
It maybe a silly question but when I loggin to my CUCM 6.0.1 to make some configurations and leave it for a while it logs out automatically..and this in some situations annoying me.
Is there a method to disable the auto-logout for any account ?
Thanks in advance
Khaled
07-29-2009 05:41 AM
No, a feature enhancement exists to a allow you to configure the timer but right now linux appliances log you out after 30 minutes of inactivity
java
if this helps, please rate
07-29-2009 06:48 AM
Thanks "java" for your feedback.would you please explain to me what is needed to configure this timer.
Thanks in advance,
Khaled
07-29-2009 06:50 AM
As i already explained this is a feature enhancement, this is not currently configurable (again, as i already explained)
java
07-29-2009 06:54 AM
Ok, I get it.
Thanks java.
