Wireless Lag (link aggregation)
Jul 29th, 2009
I'd like to know if i can be able to enable lag on the controller but termite it on 2 different switches? i.e. i have 2 ports on the controller, i connect 1 port on switch1 int g1/5 and connect port on switch3 port 1/10?
How can i do this? as i need to configure etherchannel right?
Overall Rating: 4 (1 ratings)
dancampb Wed, 07/29/2009 - 07:03
  • Cisco Employee,
No, the ports have to be connected to the same switch. Reason being you have to setup a port-channel on the switch for those ports. The only exception to spanning multiple switches is if you have 3750's in a stacked configuration.
lucky.sibanyoni Wed, 07/29/2009 - 23:30
HI.
Thanks for yr feedback.
i'd like to know then, which method can i use for redundancy? can i connect the 2 ports into different switches without lag (would that provide me with redundancy?)
dancampb Thu, 07/30/2009 - 05:05
  • Cisco Employee,
If you don't use LAG you could connect the ports between different switches.
ericgarnel Thu, 07/30/2009 - 06:19
  • Gold, 750 points or more
Wouldn't this depend on the controller?
if it is a 4402, wouldn't you want both ports on the same switch due to the npu on the controller that is shared between ports?
Trending Topics - Security & Network
