QoS Shaping Policy on Pix 515
Jul 29th, 2009
I am trying to set up a traffic shaping policy for outbound traffic on a Pix 515 to restict total outbound BW to 1 mbps. Below is the config I have set up. What is happening that uploading to external sites is indeed restricted to 1 mbps but uploading to our data centre (which has a priority policy) is not restricted. Can anyone explain why this would be as I thought the shaping applied to all traffic.
access-list test extended permit ip 10.172.0.0 255.255.0.0 10.2.0.0 255.255.248.0
class-map bdc
match access-list test
class-map inspection_default
match default-inspection-traffic
class-map video
match dscp af41
class-map voice
match dscp ef
policy-map vpn
class voice
priority
class video
priority
class bdc
priority
policy-map enterprise
class class-default
shape average 1000000
service-policy vpn
service-policy enterprise interface outside
Verify your class-map configuration command using the below URL which explains about "Bandwidth Management(Rate Limit) Using QoS Policies". Because, the class-map command classifies a set of traffic with which QoS actions are associated. You can use various types of match criteria to classify traffic. The match commands identify the traffic included in the traffic class for a class map. They include different criteria to define the traffic included in a class-map. Define a traffic class using the class-map global configuration command as part of configuring a security feature using Modular Policy Framework. From class-map configuration mode, you can define the traffic to include in the class using the match command.
http://www.cisco.com/en/US/products/hw/vpndevc/ps2030/products_tech_note09186a008084de0c.shtml#intro
