Dial peer Issue..
Jul 29th, 2009
Hi, we are using h.323 VGW.I have dial peer as below.
dial-peer voice 1 pots
destination pattern 9T
port 1/0:15
if i dial a number like 922979291, it will match the dial peer and will it discard digit 9 and send the digits (i.e 22979291)or it will send all the digits (i.e 922979291)including 9?
Overall Rating: 3 (1 ratings)
KonradStepniewski Wed, 07/29/2009 - 02:49
POTS dial peer discard all non wildcard digits, so in your example will forward number without 9.
rate if this help
Marwan ALshawi Wed, 07/29/2009 - 02:53
add one of the bellow command and will work as you want
prefix 9
forward-digits all
hope this helps
