CNA communities files export/import
Jul 29th, 2009
Im reinstalling the PC where i have Cisco Network Assistant installed.
I have created a lot of communities and i dont want to loose this information.
Its there a way to export/import the communities in the CNA software???
O. Unzueta
Alpha Systems
yjdabear Wed, 07/29/2009 - 07:42
It's saved in the "C:\Documents and Settings\your-user-name\.networkassistant\communities folder". Just keep a copy of the entire ".networkassistant" folder (note the leading dot). You may have to configure Explorer to show hidden folders/files to see it.
o_unzueta Fri, 07/31/2009 - 04:34
I have reinstalled the app, and copied the complet .networkassitant folder.
Now when i start the application i see the Communities but when i try to access one i recieve the error:
"Unable to determine the IP address of the specified device. A hostname should be specified only if it has a DNS entry. If not, the IP address of the device has to be specified".
In all mi communities mi devices were specified by an IP address.
Do you know how can i solve this problem?
Thank you.
t.goldpergel Wed, 11/10/2010 - 06:02
The config file is an xml file. It is describe the name of community in between and . I think it is must be same like name of the xml file. May be you renamed the xml file, isn't it?
