Power Injector Question
Jul 29th, 2009
I have 2 4404 WLC's with about 100 1131AG LWAP's. Every once in a while an AP stops talking to the WLC and I am forced to physically unplug it and plug it back in to get it to start talking to the WLC again.
For AP's on a PoE switch I have been able to do this remotely by disabling the inline power on the interface, and then bringing it back up. That generally works.
However - and here is my somewhat silly, but hopeful question - for AP's that are connected to non-PoE switches with a Power Injector - is there any way to remotely disable the inline power on a Power Injector to affect a similar reboot? :)
Don't be too hard on me now. Cheers.
Rob
Overall Rating: 4 (1 ratings)
Paolo Bevilacqua Wed, 07/29/2009 - 08:10
  • Hall of Fame,
    Founding Member
There is no way because injectors are passive devices.
You should figure out what bug freezes the APs in first place.
The alternative is a serial-controlled power switch.
rcoote5902_2 Wed, 07/29/2009 - 08:23
I'd love to find out what is causing the random freezing, but there doesn't appear to be any indication of what it is.
Thanks for the help!
Paolo Bevilacqua Wed, 07/29/2009 - 08:47
  • Hall of Fame,
    Founding Member
For other devices, it was said that mysterious freezes were caused by the radio module catching interference, but I have no evidence to support this theory.
